Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
Pump drains out the back into an assigned washer drain.
The machine is propped up, there is a bit of rust on the pump and a new one is on order, although not fully convinced this is the problem.
The pump begins to spin and then stops.
Everything has been taken apart and no blockages found. Even used a bottle brush to get way up to check and clean.
Hi just read your posting.Error code 37 means pump block Error,But if the pump is not the cause then the control module will be the cause.The only way to verify this is to fill the machine then advance the cycle to spin.Once the water is drained or the pump stops draining check the ohms resistance of the windings of the pump, which should be about 34 ohms, and also check if the pump is getting hot as the pump has a thermal cut out in the windings which will shut the pump down.Please reply if you need help in the testing of the pumps winding.Looking forward to your reply.
