IF THE PICTURE AND SOUND COMES BACK,,,CHECK THE LIGHT BULB IF IT IS FOGGY IT MUST BE REPLACED.
I had the same symptoms and I replaced the lamp and all is well
can anyone post where or how we go about checking the bulk as mine is doing this
Well you can extract it, it is really very easy. I got a bulb for around 135 bucks with the plastic mounting, it took all of 10 minutes and the picture is great.
If the TV has the same symptoms, just replace the bulb.
can i ask where you got a bulk for 135.00 as i am getting prices of 225
discount-merchant.com
SKU 6023
THIS IS HOW I FIX MY SONY TV WITH FIVE BLINKING RED POWER LIGHT.
PULL OUT LAMP - FIND THE INSTRUCTION ON LINE (SONY WEBSITE OR YOUTUBE) EASY
THERE ARE TWO METAL CONNECTION TABS (on top of the lamp) ON THE LAMP. CLEAN THESE TWO METAL FLAT TABS. THESE two tabs MAKE CONNECTION TO THE THERMAL FUSE. IF IT IS DIRTY IT WILL NOT MAKE CONNECTION to the fuse.
CLEAN YOU'RE LAMP WITH A VACUUM. GET ALL DUST OUT.. CLEAN OUT THE TV...THE FAN SUCKS IN DIRT. THIS WILL FIX many ISSUEs. like over heating! dog hair, dust, gets sucked inside the TV by the FAN....hmmmm
ALSO DO THIS TO ALL YOU'RE ELECTRONICS THAT HAS A FAN.
(I FEEL ALL FANS ON ELECTRONICS SHOULD BE REVERSED) but i am sure there is a stupid reason that they want the fan to **** are inside the electronics. Like hmm
THIS cleaning SHOULD BE DONE EVERY 6 MONTH
SOURCE: I have a Sony KDF-E60A20
THIS PROBLEM COULD BE SOLVED IF THE LIGHT BULB IS CHECKED FIRST,IF THE LIGHT BULB IS FOGGY REPLACE IT PLEASE.
