SOURCE: HP DV2700Tx Windows vista to XP Downgrade
you will need to download the SATA controller driver from
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&cc=uk&lang=en&os=228&product=3641490&dlc=en
without that your laptop won't recognize your hard drive there
are 2 ways to solve this:
first one you'll need an external floppy drive save the sata driver on a floppy put your xp disk in and start the install at the very begining xp prompts you press F6 to install sata driver press that and it'll get the driver from the external floppy drive.
second way is to create an xp disk with the sata driver to achieve that you'll need a deployment software i use nlite
http://www.nliteos.com/ if you have any problems add me to your msn messenger [email protected] and i'll talk you through it
SOURCE: won't start up windows xp after installing antivirus
Sounds like a virus you had on your system was linked onto one of your important system files. If you have a system rescue disk, probably included with the system you bought if you bought it new, use it. It won't delete any of your files, but it will restore any missing system files that windows needs to start.
If that doesn't work, you will probably have to format the disk and start over.
For future reference, always make a backup of your system before deleting files with viruses in them. Most anti virus programs will tell you to do this as well.
SOURCE: Toughbook lap top will not come on.
while booting try by pressing f8 button if the screen shows safe mode then boot in safe mode, if it fails to boot then you have to reload or repair your operating system
SOURCE: Panasonic CF 51 keeps shutting down
At what point does it shut down? Normally thats caused by heat and/or could be viruses. I would blow out all the ports with compressed air. Does it get into windows before it shuts down?
Ready light does not turn on and the camera does not work.
Turn on the camera (Turning on the camera).
Install new batteries (Loading the battery) or charge rechargeable batteries.
Turn camera off, then back on.
Ready light blinks green.
Camera is operating normally.
Ready light blinks amber.
Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Transfer pictures to the computer (Transferring pictures with the USB cable), delete pictures from the camera (Deleting pictures/videos), switch image storage locations (), or insert a card with available memory (Using an optional SD/SDHC or MMC card).
Wait. Resume picture taking when the light turns green.
Change the image storage location to internal memory (), or use a different card.
Ready light is off or glows steady green.
