SOURCE: colors out fo alignment
The convergence circuit is having a problem. This can be either bad connections at the pins of the convergence ICs or defective ICs. These are large black ICs attached to a heat sink and should be marked STK-XXX. If you can solder, try resoldering the pins of these ICs first. If that failes to resolve the problem, replace the ICs. The should be no additional alignment necessatry once the ICs have been replaced.
Dan
double line on top
Hi, My 53 inch Hitachi projection tv has been working fine, but now the projectors are out of alignment and the auto focus does not work to fix it. There is a concave or half moon curvature now, as though the entire projection was pushed inward. How can this be fixed, does this have to be manually aligned?
Auto focus will no longer focus picture
My TV is not aligning and the words seem bowed. Magic focus does not work.
Hi I have a Panasonic CinemaVision HDTV and am having the lifting and half moon problem, half moon on top, lifting on the lower left side.. help..
