Televison & Video Logo
Posted on May 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on May 28, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564325
Points
12312
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
Picture and colour are distorted. There seems to be a wavy shadowing effect on the screen. Could it be the colour wheel?
Hi.
If the colors do not match, then it is the convergence.
Let me know if you want more information on this.
Regards.
Ginko.
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Coulor distortion at the top left of the screen
Hello jordan ashe,
This is an indication that the green CRT is having a convergence problem. This might be caused by the convergence amplifier or by the CRT. Does the rest of the picture look OK? and in addition can you supply a picture of your TV so as I can see what you are seeing and develop a proper diagnosis?
Thank you,
Shuttle83
Hitachi 57UWX20B 57 in.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Hitachi Projection tv
*Screen Looks 3-D
*Colors wont align
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
