HP Pavilion a6000n (882780985018) PC Desktop Logo
Anonymous Posted on Oct 07, 2010
PC is stuck at the hp invent screen on boot. tried esc button while off F1, F8, F11 nothing works. unplugged all externals except mouse and keyboard. loading boot menu is displayed but it's been on this for 10 minutes.. should I continue to wait? Is there another solution? Thank you!
  • 1 more comment
  • Anonymous Oct 07, 2010
    Thank you. Are these cables easy to identify?
    I've gone through the steps and nothing change. The loading the boot menu is at the bottom of blue screen.
    Since i'm not that familiar with the inside of a pc i've unplugged what I thought I should but still nothing. I really don't know what to unplug other that the red lines and the dvd.
Ekse
Level 3:
  • HP Master 13,435 Answers
  • Posted on Oct 07, 2010
Ekse
HP Master
Level 3:
Answers
13435
Questions
82
Helped
3984756
Points
38023
Hello and thanks for using FixYa.
Often when the machine gets stuck in such a way, the hard drive could be faulty and its causing the computer to hang. If you are outside of warranty, you could open the cover of the computer and disconnect the hard drive from the mainboard. (thats 2 cables that are easy to connect and disconnect) if the machine works faster with the drive removed it confirms that its faulty.
Try connecting it again and see if its stuck again, you could also try connecting the hard drive to another connector on the mainboard and see if it helps.
If this has no effect let me know.
  • 2 more comments
  • Ekse Oct 07, 2010
    Typically, red. That is the data cable for the hard drive (hard drive on picture, contains all your files) The wider connection next to it is a power connector.
    It is enought to disconnect the red cable while the machine is powered down and all cables disconnected from the back.
  • Ekse Oct 07, 2010
    Remove the rest of such red cables and try again. from dvd drive and from other hard drives if any exist.
  • Ekse Oct 07, 2010
    okay, go ahead and reconnect the red wires to the drives, it is not a big deal if they get mixed. aslong as they are connected.
    it seems like that the mainboard is faulty or the bios is corrupt and its stuck due to that.
    I had a similar problem with a faulty mainboard long ago, it got stuck on its Asus welcome message that would get displayed when it was turned on.
    Seems like that the computer may need to get its mainboard replaced, are you in warranty? You should get HP to take a look at it, and repair it under warranty. Unfortunately since the computer is stuck and it didn't improve when the drives where disconnected, we can't do much at all, or are you able to open the setup or bios? probably F1 , F2 or possibly DEL button. if you do get into bios or setup, find a way to restore default values, it should say "restore defaults" or similar in there somewhere.
  • Bora Bora
    Bora Bora Sep 02, 2019
    It was NONE of those issues for me! After unplugging the hard drive, memory, etc. there was no positive change. Then, I decided to unplug all USB devices and plug them back in one by one. It turned out that the incoming USB port on my monitor was bad. I would never have guessed after reading all posted solutions!
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Computer will not start screen comes on HP invent
Hi.
This is a problem with HP/Compaq wherew the motherboard "freezes".
Here's a way that might just "thaw" it out.
First, disconnect EVERYTHING from the computer EXCEPT for the keyboard and mouse and screen.
Unplug the computer.
Next, while unplugged, press and hold the power button for at LEAST 45 seconds.
This allows the bios to reset to an available state.
Then release the power button and then plug the computer in.
Boot up.
The computer should now boot normally.
This is known as a "soft reset".
Hopefully this works for you, as it has worked well for many others.
I hope I helped you out, and good luck !
Internet would not work and then whole system froze. Powered off my holding start up button. Now everytime I try to cut it on it is stuck on black compaq screen. Have tried pressing esc, f1 and f8,...
Not too much.It seems you had a corrupt HD do to a virus or other issues.depends on your OS you can try to get some "boot files" in order to try to boot back your PC. After that if you cant do it you will need to re-install your OS.
Hp invent screen frozen
If the F8 key will not work upon turning this computer on the computer has a virus. A reboot CD will be needed which will correct this problem
Good Reboot disc can be purchased on Ebay from this seller.....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270517181851&ssPageName=STRK:MEWNX:IT
Ask for STEVE by name. He will respond quickly with questions pertaining your computer
I have purchased a Vista & a XP reboot disc from hime which did the trick. I had the same problem as you do
2answers
HP computer stuck on "HP Invent" screen without any of the keyboard options working- f11 setup, esc for boot menu, etc.
do hardware reset
>while printer is on unplug power cord at the back of it
>press and hold # and 6 buttons
>while holding the buttns plug back the power cord to the printer
>release when printer initilase or when you see semi full reset
>if the printer will not power back on after 10 sec press the power button
>it should ask for you to set up the language etc
>this should clear the issue
2answers
System wont boot
Disconnect all devices except keyboard and mouse and master cd or DVD. unplug then hit power button. Plug back in. Hit power and hopefully you get to BIOS. If you do make sure you save the BIOS before you leave to start OS. Keep me informed and I'll keep checking your listing to see if its working or not.
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
