Acer X233H 23 in. LCD TV Logo
Posted on Oct 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a very thin vertical red line on my screen that has appeared this morning and is is there whenever the screen is on, no matter what program I am in.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
  • Posted on Oct 06, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
0
Helped
44940
Points
825
That problem is called Vertical Problem in your TV.It might be cold solder or loose connection of board in vertical section.Need for resolder or if not work after resoldering.The vertical ic is the problem it is deffective.
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Thin white horizontal lines have appeared on the upper quater of the screen. Under these lines a greena red line has appeared. Bottom three quarters of screen is good.
u have to change a capacitor(470mfd or 100 mfd) in vertical section of u'r tv circuit board..if u r a tech person try this...
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
4helpful
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
10helpful
4answers
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
