No way. Your unspecified cellphone went crazy. Try a factory reset, though I doubt is should serve. How to do a factory reset? Check manual . Probably you should take it to your mobile Service Provider.
Hi, try my solution your problem of your cellphone SGH 525,try to restore or reformat your phone setting,but before you do that step.you need to back-up your files and save your contacts to sim memory.after you you that step you turn off your cellphone and get out your sim and memory card.just get it back the battery to your cellphone and power on,this reformat just dial *2767*3855#,after you dial that number the cellphone is automatic Restart.the result after reformat or restore is back the normal setting to your cellphone.but some data files you save is deleting.after that you turn off the phone and get back the sim and memory to your cellphone.i wish that i help you.thanks
Hi,u should try to manual format yr phone.
Press *#7780#
security code 12345.
Wait for the phone format and restart again,
After done try to check pro solve or not.
Pls rate me if my solution useful,thx..
its not possible to retrieved deleted dialed numbers from your phone because you phone does not have a recycle bin. A computer as recycle bin that's why deleted files are retrieved.
Contact your service provider, they should be able to give you a list of your dialed numbers. Usually, your service provider keeps a record of all your incoming and out going calls.
To format nokia N70 do the following procedures:
Switch of your phone
Press and hold these 3 keys together-
-green dial key-
-the star key(*)
-the number 3 key(very hard to do)
Press the on off switch to the phone
Do not let go of the keys until you see a formatting screen. After a few minutes the format will be complete,your phone will be back to factory settings.All your data will get erased.
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
- Restoring the factory settings of the phone. - Get your phone to your salesman and ask for a software update. It will not cost much and would definately fix your phone.
Looking forward to hearing from you regarding further assistance!
You may want to contact your carrier and have them walk you through checking the network settings on the phone. Some carriers require some manual input in there, and it's possible these configurations got deleted or changed unintentionally.
