Question about Dell Latitude XT2 Tablet PC
Hmmm does the penn have a battery then? I guess something is wrong with the wiring as not just the pen does not work but touching all all not. Stuff should just simply work and not require loads of troubleshooting.
Posted on Dec 01, 2014
SOURCE: Tablet PC 2005 Input Panel won't work.
Are you pressing down firmly enough? If not, sounds like the digitizer may have a problem... The digitizer is the layer in front of the lcd, it's job is to pick up the signal from your pen and send it to the motherboard. The motherboard should have two connections to the screen, one to the lcd itself and another to the digitizer. If you remove the screws on the bottom of the tablet you can take off the keyboard and see if both are connected right.
Posted on Nov 19, 2008
SOURCE: How do I enable presentation mode on an XT2
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
Posted on Nov 06, 2009
SOURCE: Dell Latitude XT2 fails to start up.
I had the same problem and was able to fixed it by using the other set of wires that connects the display to the wireless adapter (on the bottom of the laptop) ... use the grey and white/grey wires instead of the black and white wires.
Posted on Nov 23, 2010
SOURCE: My Dell XT2 tablet pen
Did you install the correct N-Trig drivers for your pen ? You can find them at http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and by entering your TAG number which is located underneath your tablet pc.
Posted on Feb 28, 2011
SOURCE: How can you get the touch screen or pen work on
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
Restart your computer.
Run Windows Update
Everything should work.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
Nov 20, 2013 | Dell Latitude XT2 Tablet PC
Nov 16, 2013 | Dell Latitude XT2 Tablet PC
Dec 14, 2012 | Dell Latitude XT2 Tablet PC
Feb 02, 2011 | Dell Latitude XT2 Tablet PC
Feb 01, 2011 | Dell Latitude XT2 Tablet PC
Sep 30, 2010 | Dell Latitude XT2 Tablet PC
Jan 18, 2010 | Dell Latitude XT2 Tablet PC
Nov 16, 2009 | Dell Latitude XT Laptop Computer Tablet...
Nov 05, 2009 | Dell Latitude XT2 Tablet PC
Jan 24, 2014 | Dell Latitude XT2 Tablet PC
Sep 17, 2017 | Dell Latitude XT2 Tablet PC
4,561 people viewed this question
