SOURCE: What is error code 7
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
SOURCE: Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
SOURCE: My Hoover 1600 AAA Vision
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
