SOURCE: The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
SOURCE: Just changed TONER & it still flashes NEED TONER.
have you removed the plastic strip from the toner which secures your toner.
SOURCE: i have a Kyocera FS-2000D i've installed a new
Turn of the printer unplug and then turn back on.
Was the toner you installed a Kyocera toner or a after market toner? If it was an after market toner that could be your issue.
