Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}/
SOURCE: como saber el codigo para
0023, 0024, 0043, 0044, 0045
Si ninguno funciona, puedes usar la función para buscar códigos del control, para esto hay que:
1.Con el televisor encencido, mantener presionado el botón de TV por al menos 6 segundos hasta que se enciendan las luces de cada dispositivo y la luz de TV permanezca encendida.
2.Presionar POWER, la luz de TV parpadeará 3 veces y se apagará.
3.Presionar la flecha hacia arriba hasta que el televisor se apague, una vez que se apague hay que presionar OK. Al presionar OK, el control guardará el código y ahora podrá controlar el televisor.
favor si alguien tiene el codigo para mi control remoto de MI TV MARCA TCL favor de compartirlo conmigo.
gracias
3001, 3002
