I have recently bought a 2001 Kia Optima, from a used dealer. the keyless remote didn't come, a friend of mine has a mitsubishi remote, will it work on the kia, and how do i get it reprogramed?
Apr 25, 2013 - 2004 Mitsubishi Endeavor Key Fob Remote Programming Instructions ... you might have visit us at Keylessentryremotefob.com You can also ...
? 2:04
www.youtube.com/watch?v=yeQRdre7O0Q
Oct 31, 2014 - Uploaded by Keyless Entry Remote Inc
... will show you How To Replace Mitsubishi Endeavor Key Fob Battery 2004 2005 To Order This Remote ...
Many times if you purchase a used vehicle, the car lot only provides the key because they do not want to spend the money to purchase a key fob. A 2006 Lancer either has a 2 or 3 button keyless entry remote which you can find here: http://replacemyremote.com/ Keyless Entry Remote Fob Replacement
if this vehicle is newer than a 2005 then its a dealer only to re-programme after changing battery as it requires diagnostic equipment that only the dealer has
The 01 Optima had the keyless entry buttons right on the key itself. I'm not sure if the LX had the option... it was standard on the SE version. In any case, programming is done at the dealership, and is expensive. They use their special "code reader / writer" that plugs into the OBD II port under the dash. You provide all keys and they are recoded to the module that is located under the stereo. A cheaper option might be an aftermarket alarm installed at a local car audio shop. They are less expensive than you might think, even installed. Good luck.
P.S. the 01 Optima remote key had a problem with very short range. You needed to be within a few feet of the doors for it to work.
i have a kia optima my keyless quit working to.I took it back to the dealer and the said it was common on a lot of kia models.They replaced the module for the keyless remote,that seams to have fixed it.
I have a 2004 Kia Optima EX V6. You have to get a new battery for your key fob(s) and take to dealer to program it. It can only be programmed when they hook it up to the computer. Cost around 40 bucks from Kia. Call around some use to charge only 10 bucks. Good luck.
Horn will not beep. No keyless entry
