I have an LG Tromm 4.0 front loading steam washer (WM2688H*M) that steams my clothing on every cycle, even delicates and handwashables? I understand this is not supposed to happen, any ideas on how to fix it?
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Hi Sgt.48,
Thaks for the info. I did what you said and ran a delicate cycle, while it was running I pushed the wash/rise and soil level buttons and saw the viewing data in the 2nd column and 2nd row, it read 28-29.
I'm not sure what the recirculatting pump you refer to is supposed to do, can you explain. Also, at closer inspection of the hook-ups, I noticed that the lines from the wall seem to be crossed. The tap that feels very hot is connected to the back of the machine labled cold and vice versa for the cold tap.
I don't know if swithching these will solve the problem b/c everything seems to be being washed w/ hot water (maybe it's not the steam).
Thank you for helping me w/ this, LG had no suggestions at!
I'd be greatful for any further assistance.
nahu
