I use a sony RM-V301 remote control for my 25vth60 sharp tv/vcr combo but when I press the menu button the menu is showed in the tv but the arrow to select the features do not moves may be I tried to use de tv buttons but whit the same resultsI use a sony RM-V301 remote control for my 25vth60 sharp tv/vcr combo but when I press the menu button the menu is showed in the tv but the arrow to select the features do not moves may be I tried to use de tv buttons but whit the same results
I tried pushing both channel buttons and it didn't work. I have a universal remote, and it will not let me press the menu button on it. All the other buttons work except the menu button.. Help! I only have 3 channels and i need to re-program them , but i cant!I tried pushing both channel buttons and it didn't work. I have a universal remote, and it will not let me press the menu button on it. All the other buttons work except the menu button.. Help! I only have 3 channels and i need to re-program them , but i cant!
im trying to hook up my nintgendo wii to my 27 inch toshiba but,i lost the remote and had to replace it with a universal and it wont allow me to switch to another imput or auxillary channel can i access the tvs menu with no remote?im trying to hook up my nintgendo wii to my 27 inch toshiba but,i lost the remote and had to replace it with a universal and it wont allow me to switch to another imput or auxillary channel can i access the tvs menu with no remote?
You can't post conmments that contain an email address.
On some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
If you do not have a remote for your Toshiba TV, there are a few ways you can access the menu to change settings or perform other functions:
Use the buttons on the TV: Some Toshiba TVs have buttons on the side or back of the TV that can be used to access the menu or perform other functions. Check the TV's manual or the label on the back of the TV to see if this is the case for your TV and which buttons to use.
Use a universal remote: You can purchase a universal remote that is compatible with your Toshiba TV. These remotes can be programmed to control your TV, and can be used to access the menu and other functions.
Connect a keyboard or mouse to the TV: If your TV has a USB port, you can connect a keyboard or mouse to the TV and use it to navigate the menu and other functions.
Use a mobile app: Some Toshiba TVs can be controlled using a mobile app that can be downloaded to your smartphone or tablet. This app allows you to control your TV and access the menu without needing a remote.
As there is no Menu button on the front panel of your TV, to perform an auto tuning function, you must have its remote control. Without remote control, it is impossible to get in to this menu option.
On older Televisions such as the one you have listed, you cannot access those menus without a remote control. Just to make sure I skimmed the user manual found here. The only suggestion I have is to get a universal remote with a menu button. Dont forget to check with your other remotes to see if they have universal functionality. Most receivers (surround sound units) have multi-function remotes. Also check your satellite or cable remotes to see if they have universal functions. You can tell, because they will have multiple buttons that say things like "TV, AUX, CABLE, ETC" If so, you can program one of these remotes (or grab one at most electronics stores to program) and have your menu available to you.
Also, check the link to make sure there isnt some functionality hidden away that I didnt see.
If there is no menu button located directly on the television set you'll have to hope to find a universal remote control that would allow for the same functions to be performed as the original remote. Otherwise you will have to get an original replacement remote.
You could try purchasing a universal remote. Many of them can access even the most specific functions, although it might be labeled differently on the remote (so if you don't see it on the remote, just play around and it might really be there. I've had my input control for a TV actually turn out to be the TV/VCR button on my universal remote). Make sure it's a universal remote with DVD controls, otherwise it might not have that function at all.
Other than that, there's nothing else I can think of, since most DVD players don't have any menu button(s) on the unit itself.
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
Is a 25vth60 sharp tv/vcr combo
