SOURCE: sharp television will not power on
Check the internal fuses AFTER eliminating power supply, power strip, etc. But it sounds like it is in sleep mode. Try unplugging it, wait 5 minutes then power up while holding the power button in.
Good Luck!
Rockinbadboy,Detroit Mi
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
SOURCE: power will not stay on to unit, cuts off after 3-5 seconds.
I am suppose to get help.. by e-mail or live chat...not give help.. Not sure what i did wrong i cant get an answer from FixYa... HELP!!!
SOURCE: WHY MY LCD SHARP LC-C3742U TURN OFFWHILE I AM
the power regulator is shot, 200-400 for a repair, sorry but you need parts
