I have a Maytag Atlantis MAV8000 Washer, and when it's done with it's cycle, it will start it's spin cycle and drain the water off without spinning. When you take the wet load from the tub and turn the machine back on it will spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
It's draining fine, just not spinning. I checked the exit hose spigot, and it doesn't appear clogged. Next idea? Thanks
