SOURCE: Troubleshooting your problem LG Washer
you may find that you need to dismantle the pump as you can get things inside the impellor area causing intermitant problem
SOURCE: buttons not working on lg washer
Could also be that the board has not been screwed on tight enough so it has a bit of play in it. You would have to check to see if the boards that are behind the display panel are on correctly.
It could also be a defect in the board.
Sgt 48
SOURCE: my lg washer turns on but i cannot select which cycle I want
The LG washers are very buggy. Yes buggy. They have an on board computer that to this day still has issues. This sounds to me like the computer is confused about cycle changes. The component is also quite difficult to change. On ether side of machine are screws that need to be removed to lift lid. There are 3 modules inside. you will need to look at the wires to see where the largest sum of wires come together. That will be the main unit. Hope this helps. Good luck.
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
SOURCE: button to turn on machine works but once i pick
You gotta replace the board, which is spendy unless its still under warranty. Might I suggest exchanging it out for a GE or Whirlpool?
