SOURCE: Cannon GP 405 error code E100, E301, E220
Sir My machine Cannon GP 405 showing code E100. please suggest what can i do to resolve this problem
SOURCE: SYSTEM ERROR E100
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
SOURCE: how do i fixed system error e100 on cannon
How many copies do you have? If over then 55000 change the drum unit.
But it can also be the laser trouble.
