Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer Leaking
My Fisher and Paykel washing machine leaks when filling and most other times, too. Upon visual inspection, the spin tub - a flexible plastic outer tub from the metal inner clothes tub - has holes in it near the fill hose. It looks like it has been rubbing while the maching is spinning and has now worn through allowing fill water and spin water to leak out. How do I remove and replace the spin tub? Also, is this problem just an indication of another problem, maybe an unlevel machine?
  • 3 more comments
  • mkratts5 Jun 20, 2008
    My washung machine as well as begin spilling water everywhere on the spin cycle totally bypassing the drain hose
  • Anonymous Jul 09, 2008
    BEFORE WASH CYCLE BEGINS ALL WATER LEAKS OUT ON FLOOR
  • mjj92455 Aug 29, 2008
    washer starts leaking during wash cycle. leaks approx, 1/4 to 1/2 pint of water during wash and spin cycles
  • Anonymous Sep 23, 2008
    Same problem. Lots of water and suds and beeping!
  • Anonymous Mar 17, 2014
    machine leaks from filling valve only on filling cycle
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
Posted on Oct 21, 2008
    New Friend:
I had my Fisher and Paykel Washer leaking, turned out the pump was getting too powerful just before failing. New pump and all is well again; they seem to last about 8 years (this is the second replacement)
Posted on Feb 26, 2017
Hi, my washer will go through the wash cycle then half way through the rinse cycle it has been making grinding noises.  I checked the hose to see if it was clogged-that's not it.  So, it beeps when it hit is rinse.  When I open the lid there are suds or bubbles and the clothes are soaked.   Please help!
Posted on Sep 21, 2008
6ya staff
SOURCE:
Inner tub base rubbing on outer tub
Sounds like you need to replace the bearings supporting the shaft. Not an easy job without the proper tools and if you haven't done it before.
Nov 07, 2015 | Fisher and Paykel Washing Machines
My machine is a 501 smartdrive and is not filling te bowl it is all going onto he floor instead
Hello there:
I will answer this in 2 seperate post's for you ok?
Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel out of balance switch fault
Machine should reset when it has regained "balance". It is possible the the OOB switch lever is stuck on the tub ( it is under the top in the right corner and hangs parallel to the tub ). Move tub around and reset load. Sometimes the OOB switch get corroded or breaks and needs to be replaced in order to clear the fault. Call F/P.
Jul 18, 2009 | Fisher Paykel EcoSmart GWL15
Leak during rinse and final spin
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
Fisher & paykel ilw16us leaks water when filling
During fill only
All the time
May 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Small amt of water drips into tub after washer stops fisher payke
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Washing machine is leaking water.
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Nov 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Repair a washing machine
During fill only
All the time
During fill only
All the time
Nov 25, 2007 | Maytag Dependable Clean Top Load Washer,...
Smartdrive 708
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
Oct 07, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
5,583 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
