SOURCE: Magic Chef MCCF5W do not works. fast freeze is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: magic chef portable freezer not cooling.
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
SOURCE: have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
