Device 10 notification likely a printer related issue. Lots of odd things can happen when HP cartridges are empty. With some HP printers, they will not run with one etimpty cartridge. There is a work around in that instance. You can "fool" an HP into thinking the cartridge is full. Of course, you would want your HP to be set to use only the black ink, for otherwise, it might try to mix a batch of black ink using other colors (and your other tank would be empty!) Now, if you are not of a mind to buy the color cartridge, you can explore the trick of fooling the HP. There is a chance that this would eliminate your device 10 notification, simply because you tell me nothing else is different. No promises, but I would have to try it. Now, just what other effect the trick might have over time is a caution. Nothing is cleaning those other nozzels. At least your HP is still working as is.
SOURCE: No taskbar or start menu?
Sounds like you have format your drive. Good practice is to leave a partition for just Windows and the other for the rest.
1 st install a good anti virvs program & check virus on all u r hard disk files & folder..
now re install windows.....
i m sure u r problem will be solved...
dont forget to vote for me...
& pls check u r moniter display setting ...
regards
SOURCE: windows explorer keeps shutting down
do a system restore to where it was working good for you.
Here is how:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
SOURCE: Continues rebooting
OK it is going to be difficult to solve this one with so many different errors. Given that this is windows Vista it is probably a bad driver. Possibly the graphics card driver. Also vista is quite punishing on hard disks so we'll start there.
First off take a backup of all your documents photos videos etc. because the check disk can cause havoc if it finds a lot of errors and can take down windows altogether. Also you must be prepared to re-install windows so make sure you have a recovery method (recovery CD's or a hidden partition on the Hard Disk) If the hard disk is truly borked though it might take the hidden partition with it. Proceed with caution and make sure you can get the PC back up and running if the worst happens.
First run a check disk. In My Computer, right click on the c drive, click on properties - tools - check drive for errors, then restart your computer and let the chkdsk run.
Post back here with the outcome.
