Hello there:
LE
Locked motor error. Cause: The connector (3-pin), male,white)
in the motor harness is not connected to the connector.
(3-pin,female,white) of stator assembly. Or the electrical contact
between the connectors. (3-pin,male,white) in the motor harness and
4-pin,female,white connector in the main PWB assembly is bad or
unstable. Or the motor harness between the stator assembly and main PWB
assembly is cut (open circuit) Or the hall sensor is out of
order/defective.
If your washer was working previously please read below.
Thermal Overload Protection
Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
