I have a PS3, cable box, blueray player all hook up to a 42" t.v. and im having a problem with the surround sound system to work for all of them at once.
I have a PS3, cable box, and xbox360 all hook up to a Samsung hlt6176s t.v. and im having a problem with the surround sound system to work for all of them at once. Cable is surround fine, component hook up xbox is surround fine, component hook up, ps3 is connected thru hdmi no surround but internal tv speaker has sound. i have the samsung htz310t unit.
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
See if oyu can buy a HDMI selector box, does the sound system have a dvd player in it? IF so I would go with S-video instead of hdmi, save the HDMI for the blue ray player. What is the very first item you have listed up there? PAnasonic what? LEt me know, hope this helps.
If your marantz amp is part of a home cinema system then depending how old it is will depend on if it will do it automatically.I have just bought a sony surround system and it detects the signal range ie it knows it is being transmitted in 5:1 surround.If you have an old system you may have to do this manually, this should not be diffecult there should be a sound setting.
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
try connecting ps3 to sound system by av connector from a ps2
