I have a 50 in. HP Plasma. There was a popping sound and I lost my picture. The indicator light does not return to green. When I turn the TV on I here a faint clicking sound from behind the TV but the pucture does not return. What is the likely problem? Thank you.
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Koala babe, narrow the problem. Is there any sign of power presence in the unit. Could be just a power issue. You did not mention any lights indication on your front panel.
