Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Motor brushes, worse case scenario motor complete. Run the following motor test. 1. Put main dial to off 2. Press and hold start button whilst turning dial one click to left (easycare 30). 3. When display show 8.88 or two of the progress light come on, release the start button 4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over) 5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin. 7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault. As suggested brushes or complete motor. Hope this helps
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first.Remove the front
lower panel, screws underneath.Be
prepared for water, drain out from drain hose.Check filter for clogging, clean out.Sometimes when the load is unbalanced & the machine cannot adjust
the load it stops.To avoid this make
sure your wash is mixed with big and small clothes. If
this does not work remove the rear panel & check belt, should have half
inch ‘give’.Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever the
motor back with a screwdriver.Check the
motor brushes (at terminal end of motor), if they are any shorter than 1 cm
replace brushes. Try
these sites for spares: RepairClinic.com
espares.co.uk
AppliancePartsPros.com mcminone.com
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
Normal
0
false
false
false
font-size:10.0pt;
Plug
adjust
half
the
cm
espares.co.uk
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
motor does not turn through any cycle. belt intact and control panel clicks
motor does not turn though any cycle. belt intact and control panel clicks.
fvhfdvhfvdhbvb
