SOURCE: push the reset button
let the camera sit alone for About 20 min,so that the camcorder automatically turned off. I turned it off,
then back on and did not receive the reset button prompt.
if that doesn't work unplug the battery and all power and plug back in.
SOURCE: Push the reset button,PANASONIC NV-GS11
My NV-GS15 asks me to push the reset button every time I turn it on
SOURCE: Panasonic PV-DV100 Mini DV...
Try to find same battery charger or camera and do Cross-Check, hook new charger with camera and confirm charging process and hook your charger in other same camera and confirm is it working? You will rectify the problem unit, either camera or charger.
SOURCE: Panasonic Mini DV NV-GS11EG "push the reset button"
i know what to do next brother go to field or a soccer field and trow the bloddy thing away
SOURCE: I own a Panasonic PV-GS31
Hi There, There is no external mic input on that model camera. The only way to do it is you will have to take the front panel off the unit and disconnect the flat mic/audio cable from the front panel. If you do this, tape up the connector so it won't short out the unit. If you had external mic in, you could put a dummy plug in and that would cut the sound from the internal microphone.
Thanks, me cicmo
