Error code 37 is pump blocked (or faulty) 'No change in water level.' Most likely you have a blocked or faulty pump motor (Not uncommon with F&P)
Thw pump motor is accessable from under the machine.
NOTE.. The machine must be empty before attempting this job.
TIP.. Lean machine back against the wall to contain the last of the water.
Make sure the 'latch' is unclipped to remove the pump motor. Turn anticlockwise to remove
Remove wires..
Check that the drain hole has nothing to prevent the impeller from turning.
Check that the pump motor turns freely..
Blow through the drain hose (from the basin end) to make sure there is no blockage..
Replace in reverse order..
If the problem persists you may need a new pump motor. These are normally checked for resistance. F&P say to replace if less than 33 ohm.
Good luck....Nomess
