Washer is "stuck" in mid-cycle and will not drain and spin. Manual suggests a drain hose issue. Have tried to drain and spin, machine seems like it wants to do this, but can't. Tried all troubleshooting options, nothing has helped. After a few minutes, all lights around cycle choices flash. What's the deal? machine stopped in mid cycle won't spin or drain. door locked and add garmen lights both go on when I try ti restart. After a few minutes all lights on front panel start to flash.
Remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
I have this same issue. Sometimes it works other times it won't. back flushing the drain tube seems to help sometimes.
Lights on front panel flash on and off. Machine may or may not start. if starts, may or may not complete wash process. Machine may stop mid cycle and not restart.
unplug/re-plug does not change symptoms.
