Does washer fill, wash and drain? This washer is a straight forward unit and that complicated like new front loads. If unit fills, wash and drain, then I would lean toward a timer issue. With the unit filling, washing and draining, that tells me lid switch is good, motor runs in wash direction, pressure switch is working and tub is not locked down. Also, if motor turns one way, then motor is good. If unit is not doing the three things, then could be lid switch, pressure switch or bad motor.
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Check door switch: If
the lid switch is bad it will not drain or spin. Try this test: With lid open
let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining.
Release switch. Motor should stop. Press
switch a second time. Washer should
start spinning as it continues to drain. If motor doesn't come on while lid
switch is pressed, replace the switch.
OR
http://www.youtube.com/watch?v=q942xn_2VXY
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
