Cars & Trucks Logo
Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AC was weak so had it recharged. Everything was fine for the rest of the day. Next morning I started the car, turned on the AC, was putting junior into his carseat when the AC quit. I turned it off then back on several times and the fans would come on then go off. Then nothing. And I mean nothing, no lights on the control panel, no fans, nothing on heat or air. I tried for a week, checking connections, testing fuses, nothing. Then I drove it out to my sons house, about 30 miles. On the way back I set the fan control switch to low. Nothing was working but I just set it anyway. About 20 miles into the drive, it came on. Was a cold evening, it came on economy and hot so I turned the temperature control down and set it to auto, but didn't touch the econ switch. Didn't try the AC system, didn't think of it. As soon as I killed the engine I began to wonder if the AC might be working so I started the car back up. Nothing. No heat, no AC, no lights everything was dead again. I haven't been able to get it to come on again. I've checked fuses, relays anything I can find but nothing. Any Ideas, I'm at a complete loss. Appreciate your insights. Rick
gerry bissi
Level 3:
  • Jaguar Master 4,390 Answers
  • Posted on Oct 15, 2010
gerry bissi
Jaguar Master
Level 3:
Answers
4390
Questions
Helped
3058546
Points
11499
Read the owner manual to see how the auto works. try the defrost mode whcih is a fail safe mode and should always come on unless a major system issue.
Temperature won't change from ac to heat in 2015 Chevy equinox
There are two ports in the air conditioning system of Equinox. One is labelled H for high-pressure and the other one is labelled L for low-pressure. You can recharge your AC through the low-pressure port with a do it yourself AC recharge kit.Shake the canister briefly and release the refrigerant into the system until the recommended pressure has been achieved. Note: See next section for recommended pressure values
My perguote 208year will not start until 34 turn over have to put foot on excelarater in mornings to start after that no probplem start right away till next morning same problem.
get ignition coil checked. If it is EFI DO NOT press on Accelerator when starting it.
Could have a leak in fuel and it evaporates over night
if carby fuel may be leaking out over night as vapour. In mornng you are fuel pump refilling fuel into carby until it starts again.
Kia air conditioner doesnt work
I have a 2007 kia rondo.Ac was working,parked it for a year,ac wasnt working,recharged,the ac,it worked for a month,an started again,blowing hot ai.If you let it set for hour would start working...then after a few days it would only work early morning,if you dont turn ac of,then it stop working,I see the clutch isnt kicking in,ir you try an put freeon in it soon as you start putting it in it would kick on.An its full of freeon.
We just got our A/C system (2000 Chrysler 300) recharged with Freon and at that time it was discovered the A/C belt was gone, so that was replaced. Everything seemed fine on the short drive home - AC...
Not real likely, but it was HOT outside, correct? has it overheated since? It is likely the thermostat was weak or bad, but this is a June post. Do you need further help?
2helpful
My 1998 windstar shuts off and wont start
charge battery up 2 amp slow charge,could take 24 hrs,,, put a volt meter of any kind that goes up to 20 volts or more,and it should be charging 13.50 to 14.25 with nothing on then turn ac on and fan on high and head lights on bright it should stay around13.25 to 13.75 if u dont get these readings replace alternator
Car wont start in the morning
a toggle switch will work as long as you put the right fuse in it..Good Luck
Ignition locks up!
Try spraying a little lubricant in there, if you haven't tried already, like silicone spray. Make sure you push hard into park & press brake pedal harder as well, and wiggle steering wheel hard.
1helpful
2answers
Engine turns over fine , car will not start.
well the first part of your question i was all ready to tell you to put a new fuel pump in, now not so sure, there is a relay for fuel pump, can you hear pump cycle and relay click? relay under hood you will have to listen close they don't run long maybe a couple secounds, if you don't relay bad. if you do pump could be bad, do fuel pressure test pump could be weak. don't think sunroof and turn signals are related, but stranger things have happend.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
