It vibrates but does not have a ring sound
Did you try the switch on the left side of the iPhone?
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
asdew
Mine was happened after using the headset which was provided with the iphone. i try the phone with the headset it works fine i get the rings as well as the vibrate. i think problem is in the socket . locks into the headset mode. i ma trying to sort it out at the mo. if i succeed i i will let you know.
try withe the headset on and ring you number im pretty surre you will her the ringtone.
hahahhahaahha
mine is working ok now!!!! i tried differnt headset as well as the original one .and while i was sysnc with i tune i got a call from my mate . and started ringing
worked
good luck
i tried mine more than ones now . it does work just plug and unplug the headset few times and live it for a while .ring your number see waht happens . like i mentioned earlier if you used your headset with the iphone it goes onto headset mode and stays there for a while . by pluging and unpluging the headset releases the headset mode!!!!!!
good luck
see more info at
www.giorentals.com
That's it!!!
thank you very much
SOURCE: İPhone not ringing
You may want to check this:
On the iPhone on the top, left-hand corner, there is a toggle button which controls your settings for silent or ring.
Here is a thread on Apple forums.
SOURCE: iphone doesnt vibrate
I had the same problem: my phone wouldn't vibrate at all... I read a lot on other forums and found the following solution: If you turn the phone face down, and hit it on the metal side a couple of times (I hit it with just enough force not to cause it any damage) the vibrate will come back on. I almost didn't believe this, until I tried it.
Good luck to you all.
iPhone vibrates and sound occurs for text, emails, etc. just not phone calls.
But now the following... I have a broken switch, the Bypass your switch patch works fine for all audio except the Phone calls , only fibration and no sound.. any idea ?
my iphone justs vibrates for everthing i didnt break anything
my iphone does not ring or reconize charger
My Iphone does not ring.. it is always on vibrate mode I can't get it to ring
My iphone will not make a sounds but will vibrate. The switch on the side does not show orange so this is not the problem.
SAME PROBLEM! My settings are correct. It should ring with every receiving call or message but it just vibrates. My volume is set all the way high. I don't have is in mute. It just refuses to ring. I tryied resetting the original settings, restoring, etc. nothing work. Please help.
Thanks
iPhone will not ring on incoming calls, only vibrate... the silent switch is not the problem, but when I switch from silent mode to ring mode nothing happens (no bell icon). Have tried restoring, rebooting, etc... It did work initially, and then stopped ringing a few days after the phone was jailbroken. It has now been restored and updated on iTunes, and still not working... only vibrates on incoming calls.
ditto
