Casio Parts Cash Register PC Desktop Logo
Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cash register doesn't register that I have scanned a barcode. The scanner beeps and sends the data, but nothing happens on the register (SE S300)
Electroboy
Level 3:
  • Casio Master 1,888 Answers
  • Posted on Oct 16, 2010
Electroboy
Casio Master
Level 3:
Answers
1888
Questions
Helped
674356
Points
3733
Has this scanner been working on the register previously, or is this a new setup?
If anyone needs a Casio SE-S300 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
After scanning a barcode no data is entered and scanner stops working until it is unplugged and plugged back in
Try resetting the scanner or replace it altogether or better still call a technician
When I plug in the barcode scanner it stays on flashing and will not scan a barcode
Hi Carolyn
I am going to presume that you have not set up the Barcode scanner yet with the barcode EAN defaults etc? Please take a look at the PDF document via the link below and go through the setup process for the barcode scanner.
Andrew
Sharp XE A507 Cash Register
5helpful
I have a SE-5300 Casio cash register and I want to reset everything.
I think you mean an SE-S300. If so, pull a battery out. Turn key to REG mode. Turn off at wall, then back on. Put battery in. Be aware that this will lose all programming and sales data. You will need to re-program from scratch.
If anyone needs a Casio SE-S300 manual, the programming manual is here:
My metrologic orbit scanner ms7120 wont register with cash resgiter
I think you've answered your own question. Spilling water on any electrical equipment will inevitable cause failures. It requires a repair, which we can do for you.
If you require an help on this scanner please dont hesitate to contact us
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
Casio TE 2200 we are trying to input barcodes using the scanner. The Scanner beeps indicating it is reading, but the cash register does not show any acknowledgement that anything has transpired. There...
There is nothing simple about bar code systems unfortunately. Has this scanner been working with that cash register previously? Have you had a training session with the dealer when you bought it? The dealer should have set the system programming in the register and the scanner should have been set for the correct interface parameters. The Cash register settings can be found only in the dealer manual. If you want to check them yourself, the manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
2helpful
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
2answers
Casio TE-4500F cash register scaning problem
There are several things you will need to do. In the I/O program you must tell it where and how the scanner is set up and then you will have to program the scanner itself. I know this will solve it. I need to know the make and model of scanner
1helpful
Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
No green ready light
There are two different type of port usually experience this particular problem.
1) If you use the scanner to com1 computer port
2) If you use the scanner to com1 cash register
The only way to settle the situation is to use the manual barcode scanner default settings.
1) Setting up default for com1 scanner
2) Setting up default for com1 cash register.
If you barcode still experience the problem you need to contact the manufacturer on that model or the reseller where you bought the said device.
Probably, the device being situated in critical effects that your scanner would not able to determine where it will send the data from your barcode scanner.
Please rate me solved if you like my suggestions.
Best regards,
Philip
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
