Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Makes a loud squealing noise for several seconds and then it will correct itself, it is starting to get for frequent... any ideas?
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Oct 21, 2010
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
143022
Points
1214
Is this in Spin Cycle or wash agitate cycle.
If Spin Cycle then possible Outer Tub Bearing issue. Big job but most DIY types can deal with the repair if you can deal with some down time........but need more info on the issue.
Noise in engine compartment - chirping, then loud squeal
try having the radiator cap checked for performance. It is not in the engine as any change in rpms would cause a corresponding change in frequency and volume of the noise. However if there is a problem in the cooling system ( leaking head gasket etc) then as the pressure builds up and escapes from under the radiator cap it will give the same affect as a bad tap washer in the household plumbing. Turn it on slightly and the water squeals as it comes out ( tap washer vibrating from pressure fluctuations. I would suggest that a coolant pressure test and a compression test may be in order to eliminate what I have suggested.
2helpful
I have a loud squealing noise upon starting the car. the squealing normally lasts about 30-45 seconds. sometimes the noise will appear aftrer pulling off from a stopped position, as well. all belts
Try to tighten the belts a little firm.Sounds like when engine idling no squelling only when about to take off .Some times belts may seem ok on the outside but if you look on inner side you tend to see cracks in the belts .
1helpful
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
2helpful
Just replaced belt and alternator. Engine squeals very loud when started. What should I check next? belt tension seems good.
Sounds like the new alternator was run without first fully charging the battery (12.3 - 12.8 volts)
This will destroy an alternator every time -- the classic symptom is a squealing belt.
2answers
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
