Don't leave gas in the tank, or add additive to gas >>> you know that but the next reader might not know.
If you are able to get washer running by spraying WD-40 or some other accelerant directly into carburetor but engine will not continue running ... there are 3 suspects: 1) dirty air filter 2) the exhaust port is clogged with carbon, dirt, etc 3) the carburetor has given out or no gas is getting to carburetor
2) Check exhaust port >>> we finally broke the screen out with a screwdriver so it wouldn't bother us any more
3) Carburetor ... you have spark but the gas is either not getting to carburetor or carburetor is not letting gas in. Pull off rubber line going to carburetor and see if gas flows out. If gas gets to carburetor and all the conditions above are met, then the carburetor needs gum out or rebuilding or replacement
