JVC AV-56WP30 56" Rear Projection Television Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red wave line on screen - JVC AV-56WP30 56" Rear Projection Television
John Long
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Oct 17, 2010
John Long
Expert
Level 2:
Novelist:
Answers
153
Questions
0
Helped
48554
Points
466
Sounds like one of your convergence IC's has failed. One easy way to find out is to go into the menu and try and adjust the red if it wont move then its for sure defective. You called it a wave and the typical of convergence IC failure. Your set either has 2 or 3 convergence IC's and I would replace them all. If you can solder then you can do it yourself other wise call a tv shop and ask what they will charge to replace them.. there part numbers usually start with stk392-xxx take the back off and you can see them. They are about 3 inches wide and 2 inches tall and black.
My LCD Samsung tv screen I red instead of black and the picture has waves of red
Sound like a LCD panel problem, but get it diagnosed to be sure.
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Our sony 51" projection tv has waving red lines
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 53fdx20b and it has a wave acrost the top
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
1helpful
2answers
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
