If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
