Question about iLO LCT32HA36 Television
ILo tv My iLO LCT32HA36 tv is stuck on standby do you have any soulutions?
  • adicerson9 Jun 23, 2008
    TV is stuck in stand-by (red led is on). I can not turn it on with the remote or power button on set.
  • 2,337 Answers
It looks like the power supply failed on your TV. If the LED is solid red or green, it could be some leaky or dry capacitors but if the LED is blinking, the failure is more complicated to repair.
I service these power supplies. If you need more info you can send me an email to jah2mil@hotmail.com
Posted on Jun 04, 2008
6ya staff
SOURCE:
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
I found a ilo 32 hdmi t.v. model lct32ha36, there is not a button that says on/off. Just a standby. I want to figure out if it works before I by a remote to test it. Can you suggest anything?
Most new televisions are actually labeling the "power" button correctly. Unless a tv is unplugged, it is never really off. It just goes into a state of standby. This is what you would have called your power button.
Jan 03, 2012 | iLO Televison & Video
How do I get it off standby?
Hi there, I came across a website that has the answer for any problem of different televisions including ILO http://tv.manualsonline.com/ex/mfg/headline/m/ilo/d/flat_panel_television/type/product_problem. Hope this helps.
Feb 17, 2011 | iLO LCT32HA36 Television
LCT32HA36 Television does nothing. The standby light does not come on when plugged in.
Check the power source?Yes,than the tv power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 29, 2010 | iLO LCT32HA36 Television
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
ILo tv stuck on stand-by
there is some internal problem, maybe you must reheat the IC's inside or there is probably defective parts. Try if it oscillates if you turn it on by monitoring the collector voltage and it must be around 100 to 135 volts.
Jul 30, 2008 | Televison & Video
Remote code
There is no code for the television you may be able to use a UN11000 - call 800-726-4405 - Ilo is made by ESI - who also makes the Akai, Viore, and Scott brand tv's.
Mar 03, 2008 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
417 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
