Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
Check your present remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Sidebar" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
The RedOctane Guitar Hero Wireless Drum Controller for the Wii is powered by the Wiimote. To replace the batteries for the drum set, you would remove the Wii remote from the drum set, replace the batteries in the Wii remote, then reconnect the Wiimote.
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine.
• Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries.
• Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten.
• If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
Turn on the component to be programmed.
On the remote control, press and hold the SET button until the
SET indicator lights up.
Press the appropriate component select button for the component being set
up.
Using the number pad, enter the component's manufacturer code.
NOTE: If more than one code number is listed for the manufacturer,
repeat the procedure, entering one code at a time until you find one that
works.
Press the ENTER button.
Point the remote control at the component and press the POWER
button.
NOTES:
If none of the codes listed for the manufacturer work, it may be necessary
to try codes listed for other manufacturers or perform a search for the correct
code. Consult the Operating Instructions provided with the remote control for
steps on searching for the correct code.
If a new code number is entered, the code number previously entered will be
erased.
When the batteries are replaced, the programmed codes may be erased. It may
be necessary to reprogram the remote after replacing the batteries.
The operation of a combination deck of any kind is not guaranteed.
Some product functions may not be able to be controlled by the remote
control. Use the remote control provided with the component.
In some rare cases, you may not be able to operate your non-Sony equipment
with the supplied remote control. This is because your equipment may use a code
that is not provided with this remote control. In this case, please use the
equipment's own remote control.
If programming fails, it may be necessary to reset the remote control. To
reset the remote control, remove the batteries and press each button on the
remote control twice.
try one of these codes 003, 013, 012, 030, 046, 050, 051, 049 here are some instructions
On the remote control, press and hold the SET button.
While holding the SET button, press and release the POWER button
Release the SET button.
Press the appropriate component button for the component being set up.
NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
Press the ENT button.
Point the remote control at the component.
Press the POWER button to verify operation.
NOTES:
If a new code number is entered, the code number previously entered will be erased.
When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
