Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Devise cannot start. (code 10) - Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Rusum Gupta
Level 2:
  • Expert 102 Answers
  • Posted on Oct 18, 2010
Rusum Gupta
Expert
Level 2:
Answers
102
Questions
0
Helped
19698
Points
440
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Wipro laptop PC not starting Only widows starting automatically option is repeating
go to boot menu and check your setting about firstboot devise.sure first boot devise is hdd than restart and show if problem not remove than return into boot menu and change first boot devise into dvd rom and reinstall your oprating system whith your oprating system cd..
What is the pairing code?
The pairing code is a sort of a password that only the primary sender will have on their devise and this code in turn reflects unto the secondary receiver. Failure to insert this code within few seconds the devise will fail pairing and you have to start over again, switching bT on and off again.
What is the codes for gpx dvd player d1816,-----using a rca univesal remote ?
i would go to the rca website and check with them there is a way to do it with out a code from the book i just cant remember the exact sequence,i think you turn on the device then press the devise button and hold power till the power button starts blinking then keep pushing the power button till the devise goes off then you must hit the stop button on the remote right after the devise goes off then you should be able to turn the devise on using the remote
My dell inspirion all the sudden wont find wired networks and in the device manager it says "this devise cannot start (code 10)
Code 10 means that the drivers are not installed properly. May be that the drivers need to reinstalled or rolled back
Try rolling back the drivers first, that should resolve the issue for you. this can be done from the device manager itself. right click on the device, then click on properties and then on drivers and then click on rollback.
Else you may uninstall the drivers and then reinstall the drivers from Drivers & Utility disk.
If you need any further help then you may call us at 859 309 7078 (US) or reply over here.
If you want me to take the remote access of your computer and help you out then log on to HNetworking.com
V5340 error code 14
first check if your tapis open if ok, check your water valve if it is clogged or busted, it is th electrical devise that controls water flow to your machine, if it is busted replaced the water valve, check the nearest part center in your locality, , otherwise a tech should check the unit, error code from 10 to 15 refers to water supply of your machine sir.
2helpful
I have a slimtype dvd a ds8a2s a ata device that I get a code 19 device cannot start message in device manager
Fist, go to devise mgr, --start button, in search area type devise,
find the devise, it should have a yellow shield, click on expand so you see the actual drive, it could be open with the shield next to it already.
It will be under cd roms. right click on it and choose uninstall, yes
uninstall the devise, now cold boot , shut down the computer and restart
it and wait until windows says found new hardware, if it doesn't throw the error when installing or after installing, go back and check it for the yellow shield.
Universal remote
i would go to the rca website and check with them there is a way to do it with out a code from the book i just cant remember the exact sequence,i think you turn on the device then press the devise button and hold power till the power button starts blinking then keep pushing the power button till the devise goes off then you must hit the stop button on the remote right after the devise goes off then you should beable to turn the devise on using the remote
Cd-rom driver code 10
go to devices in control panel check drivers for cd dvd player if yellow mark on them delete and reload them
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
