Olympus SP-350 Digital Camera Logo
Deidre Sellers Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello: I am trying to obtain a data transfer cable for an Olympus SP-350, 8.0 megapixel camera. So far, all Internet searches have turned up nil. Thank You for your assistance. Deidre
sonic boom electronics
Level 3:
  • Master 1,557 Answers
  • Posted on Oct 18, 2010
Master
Level 3:
Answers
1557
Questions
Helped
386199
Points
5474
Try www.cables.com we use then a lot
Hello, My olympus sp-500uz has more and more problems with connecting to my PC. Some USB ports don't work any more(front connection) and the back connection works sometimes but getting my pictures on the...
Many people find it more convenient to just take the memory card out of the camera and put it in a card reader, especially now that these readers are built into computers and printers. That would be a "work around" for your problem.
As to the problem itself, a bad cable might be the cause, with damaged connectors. That is something you can replace cheaply (search Amazon on "Olympus SP-500 USB") so it won't be expensive to check it out.
Slow transfer might be due to using an older standard USB port. The first USBs were much slower than USB2 widely used now. Some older computers only have the earlier standard, and some have a mix of old and new.
1helpful
User Manual for an Olympus SP-350 8.0 Megapixel Camera?
You can download and print the instruction manuals in PDF format by clicking these links:
Basic Manual
Advanced Manual
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Can I transfer memory picture to the SD card?
Probably, but why struggle, there's loads on ebay dead cheap hers's one:-
Item number: 230493049482
I havea an olympus sp-350, shutter is stuck so
I had the same problem, so tried putting the zoom fully on to take a picture.
It worked.
Sp 350,says software not recognoized by camera
It could be yet another glych with Vista. Try contacting the Microsoft website, and if there is not a specific patch available - email them.
The Olympus website may have something -
NEW DOWNLOADS FROM OLYMPUS
If this still does not work - Email Microsoft or Olympus directly, as you may not be the only one in this situation.
2answers
Can't transfer pictures to my computer
I work as a Olympus DTS Agent. It sounds like your cable is bad or your Port on your camera is bad. One tip that I can recommend other then calling us at tech Support 1-888-553-4448 is be sure you are always plugging camera in through a usb port on the back of the computer.
1helpful
SP 350
The answer to your problem might lie with the OS you are using. For whatever reason, when Microsoft brought out Vista it broke a lot of old programs and devices that worked perfectly fine. Why backwards compatability is beyond Microsoft, I don't know, but its an unfortunate circumstance.
Here is a link to Olympus' website, and a direct link to the SP-350 download page -
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1188&os=w
I'm not sure if the drivers on the page are for Vista, its very vague but this is the first place to start.
5answers
Sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty  of sellers out there.
Olympus SP-350 USB Device Not Reconized
Hi
You have to take out the card before you switch on the camera. Switch on the camera and then put in the card. Then it works
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
