Is this gas or electric? If it is electric, you will want to test the power to the burners with a voltmeter. This will tell you if the control is bad and not giving power to the burner, or if the burners themselves are bad or possibly just loose or corroded connections.
If you have gas, check the gas valve and the tubing. Make sure there are no holes or gaps letting out the gas, make sure the valves is completely up to allow full gas flow. Also check that the tubing is clean of debris.
