Question about LG 60PK550 TV
I have the LG 60PK550 model tv and i have a lot of buzzing noise coming from the set and wondered if this is common in plasma tv's of this size due to the amount of power they consume ?
  • LG Master
  • 8,457 Answers
No,the power supply board have problems.Those power supply transformers on the power supply board,causing this,high voltage flow going through those transformers.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 18, 2010
  • 2 more comments
  • Anonymous Oct 18, 2010
    so is this something that LG will look after...the tv is less than 2 months old ?
  • Chi Chu Oct 19, 2010
    Call LG for a warrenty repair,the power supply board LG probally replaced it for u under warrenty repair.
  • darren_x Oct 21, 2010
    I emailed LG about this, too. It is repairable under repair. The service rep said that this is a known problem with "some units", meaning that not all units of this model number have this problem. I am buying the same TV next week.
  • Chi Chu Oct 22, 2010
    So LG going to repair it for u under warrenty?Or u going to return this tv,where u bought it and get another one?
I have a 50" LG LCD flatscreen TV. The screen is white and blurred out. I got the TV from a friend and am wondering what is wrong with the screen. There is also a buzzing noise coming from the back.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 22, 2016 | LG Televison & Video
LG 60PK550 suddenly shutdown,when i turn it ON the relay work and then shutdown without any signal or any thing on screen
Sounds like main board fault. Anyway visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
It has details about how to troubleshoot a Plasma TV. Do nt bther about the brand of the TV. Almost all plasma TVs will show similar faults.
Jun 11, 2015 | LG 60PK550 TV
60pk550 tv has sound and no picture ?
Contact the authorized service center for LG. Your TV need a through checkup. Gopakumar Gopalan Google
Aug 08, 2014 | LG 60pk550 60 1080p Plasma Tv 60pk550
No picture
It's obvious that the power supply failed. The most common parts in a power supply are a thermistor or a voltage rectifier, possibly even a voltage regulator. diodes or resistors can act as fuses too. A ringing sound can come from a fixed coil that isn't kept still with enough epoxy. Hope this helps.
Nov 26, 2013 | LG 50PS60 50 in. Plasma HDTV
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Buzzing noise from 42 inch Samsung Plasma TV
this is a comon occurance in theis model it is caused be loose laminants in the switching tranformer sometimes it can be fixed by covering it with clear GE silcone
Dec 01, 2009 | Televison & Video
LG 60PK550 TV Logo
718 people viewed this question
Ekse
RONALD CARTER JR
