SOURCE: camera error # e45
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
SOURCE: error E45
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
found this helpful.
Regards
Andrea
My camera will not turn on or off with the lends stuck open. It gives me a E45. What is a error E45?
my camera will turn on ,but then goes to the error message # E 45 can i just fix it myself ?
camera has error # E45 and the lens wont retract
Camera has #E45 and it won't retract.Please help
I also have E 45 come up on my 4 years camera,what error is this? Karen
i was taking pictures with my kodak v603 camera and it said error #e45 and the lense wont retract and it makes a clicking motor sound when i try to start it up again. what is wrong with it and what can i do to fix it?
When I turn on my camera, it buzzes, then the screen diplays Camera error #45
when turnign on the camera makes a whirring sound and says camera error E 45.
camera error e45
how do I read the solution- the smiley link does not open up
Make and model?
