Hoover Master
- Posted on Oct 19, 2010
Re: Drum does not turn in wash cycle or spin
Hello first thing to check is see if the belt as snaped, if ok then it may be down to the brushes on the motor you will have to take the back off to check . you should see 2 black plastic clips on the motor . the motor may be located at the bottom of the washer. hope it helps
regards
shaun
