Behringer XENYX 2442FX Mixer Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Oct 19, 2010
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532186
Points
2214
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
3helpful
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
How to connect a Behringer XENYX 2442FX Mixer to a laptop
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
How to connect ddx3216 to pc
You need to either connect it using a MIDI interface card and cables from the PC or you can use a RS232 serial cable which may be hard to find for your PC. It appears to use the 7 wire RS232 type connector at the mixer board end. You can get USB to MIDI converter devices from several sources.
1helpful
I purchased a PV12M monitor and was wanting help connecting it to my Behringer xenyx 2442fx mixer
You will have to have an amplifeir between them since the PV12M is an unpowered speaker. The Xenyx 2442FX is likewise an unpowered mixer meaning it cannot directely drive a speaker. You will wire with a balanced line (TRS cable) between the 2442 and the amp and then from the amp to the speaker using a speaker type cable.
I need instalation diagram for tascam DR-1 to behringer 2442
We don't have any graphic means of diagramming. You also don't say if this is for recording or playing or both. Assuming it is both, your best way would be to get two 1/8 stereo cables that split into two RCA plugs. Go from the headphone out of the DR1 to the CD inout jacks on the mixer. Then with the second cable go from teh CD out jacks of the mixer to the line in of the DR1.
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
1helpful
Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
