Question about Maytag MSD2756G Side by Side Refrigerator
Maytag Performa side by side refridgerator. Water is leaking from behind the panel on the freezer side of of the fridge. Through the vents on the back panel there is a heating coil that seems to come on periodically and gets hot enough to glow. Why would there be a heating coil in a fridge and what do you think the problem is.
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Sounds like a stopped up defrost drain is the reason for seeing water in freezer. That heater is part of the defrost system and should normally come one every 8-12 hours depending on your models defrost cycle b
Posted on Nov 19, 2017
Anonymous
SOURCE:
Anonymous
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
Anonymous
  • 126 Answers
SOURCE: GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Posted on Sep 17, 2008
Anonymous
  • 171 Answers
SOURCE: Maytag Performa Model # PSB2151GRW Fridge is
Your compressor is damaged. It must be either serviced or recharged. This is going to require a service call no matter what the solution due to the need for recharge after the compressor is replaced.
Posted on Oct 02, 2008
Anonymous
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Posted on Mar 10, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: "maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
Posted on Apr 29, 2009
Refridgerator side by side not getting cold
When we had this happen, the air vent between the freezer and fridge side was blocked with ice and wasn't letting the cold air come thru from the freezer. That's what cools the fridge. Our vent was up at the top between the two.
Jul 17, 2011 | Maytag Refrigerators
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
134 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pierre Laplante
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
