Mitsubishi VS-50609 50" Rear Projection Television Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi vs-50609 wont stay powered on
When I turn on my Mitsubishi vs-50609 the power light comes on then you hear the tv station sound for only a second without the picture showing and it stays on for only a second before turning off. It does this every time and I am unable to watch TV.
  • lahai senesie Jun 05, 2008
    the problem is with my hp laserjet 1320 printer.when i power it on it can not initiallize and the power light is constantly in orange
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Jul 20, 2008
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302287
Points
1655
Good day, carriegomez;
If still have problem try this or at least you will have an idea of what's wrong:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) I hope this was helpful, big IRISH.
Anonymous
Level 3:
Genius:
  • Master 1,139 Answers
  • Posted on Jul 14, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1139
Questions
Helped
413307
Points
2179
Hello carriegomez,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
1helpful
Why won't my Mitsubishi VS-50609 big screens power stay on?
There's a problem with the power supply or another board drawing too much power from it. It needs a service tech to determine which.
4helpful
1helpful
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Tv turns on the
Power converter board it dead.
Need to be replace.
1helpful
My power button does not stay on (the green lamp)when turned on from the remote or the unit. I checked the fuses on the main circut board and the have contineuity. help model vs-50609 mitsubishi rear...
Could be h.v. splitter.pull the lead coming from the flyback that enters into the h.v.splittter. Put lead in a quart jar and turn the set on and see if you hear a hissing sound, if you don't see a blue arch also. If set stays on then h.v.splitter is bad.
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
1helpful
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
POWER DOES NOT STAY ON...PLZ HELP
Hello carriegomez,
It sounds like you shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Hello nicolastran,
Thank you,
I hope this helps
Shuttle83
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
