Question about Horizon Fitness T90 Treadmill
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
    New Friend:
  • 14 Answers
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Posted on Oct 25, 2010
6ya staff
SOURCE:
Hi I have a horizon t4000 premier treadmill, everything seems to work fine when I plug it in, it all the console displays fine, but p1 (programme 1) just keeps flashing and no response from any of the
Hi Anthony, sounds like there is a bad connection from upper to lower, a pinched or bad cable, or bad solder on a connection point.
With the "flickering" of the console lights mentioned, this tells me that the power supply connections to the console were suspect at one time, and doing nothing and having it "work ok now" is not a good sign of something being fixed. Also, with the flickering, this would mean the upper board would be intermittently powering up / down, causing massive trouble with the onboard CPU which is trying to operate the system. I would advise against using the unit the way it is, and have the control board checked. You can contact jatinah electronics for further help if needed. Good Luck!
Jan 11, 2015 | Horizon T4000 Premier Folding Treadmill
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
Sep 09, 2011 | Horizon Fitness Horizon T101 9 Program...
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Horizon Fitness T90 Treadmill Logo
779 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
