Question about LG 42LC2D 42 in. LCD HDTV
Coloured lines down the right side of screen - LG 42LC2D 42 in. LCD HDTV
    New Friend:
  • 4 Answers
If the lines extend top to bottom and are thin, then the LCD panel is most likely defective.
Posted on Oct 21, 2010
    New Friend:
I'm having Problems with my LG Plamas TV.
coloured lines down the right side of screen not only one there abt 15 blue line..
Posted on Nov 29, 2010
2 Suggested Answers
Anonymous
SOURCE:
Azrael SRL
  • 11800 Answers
SOURCE: vertical coloured lines down right
No, gas problems would have generated failures all over the screen, not in distinct lines.
No, these lines are caused by badly functioning buffer boards: the chips on it that directly control those specific lines of pixels overheat and start to malfunction. The problem is getting worse because the status of the chips is getting worse: they need less and less time before starting to fail. In the end it will fail for good and those lines will be permanently on the screen.
The faulty buffer board will have to be replaced. You should call a repairman to do it - to access them the entire tv must be completely dismantled and this is a very tricky operation in a plasma tv. On top of that the replacement board is very hard to obtain by a regular person, it will have to be ordered at the dealer. Fortunately it's not an expensive part - less than $40 per piece.
Posted on Feb 05, 2011
My LCD TV has developed about twenty different coloured lines down one side of the screen, can anybody tell me if I can fix this.
sounds like the Tcon board is causing the lines which is very common issue when the Tcon fails. You can get the replacement Tcon form www.tvrepairworld.com
Apr 05, 2013 | Televison & Video
In My Acer LCD X173W,Appears Coloured lines on the right side.
disconnect all the cables from the monitor except the power you wouls see a test screen .
if you still see the lines its the monitor is bad better buy a new one as repairing is expensive .
Apr 17, 2010 | Acer X173WB Monitor
White line on screen easynote mv35-202
Replace the LCD screen. Its problem with the LCD panel.
Sep 07, 2009 | Computers & Internet
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
May 28, 2008 | Samsung Televison & Video
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Coloured line about 3 cm wide down right side of screen ACER 1640 widescreen laptop
The only other thing that can be done to check that it's not a software problem is to go to my computer>right click>properties>hardware tab>device manager and look down the list for 'Display Adapters' and click the '+' sign and right click and select uninstal. Restart the laptop and the graphics adapter will be installed automatically and the driver installed. see if there is any change. To find out if it is a driver fault, press F8 on startup and select 'Start Windows In Safe Mode', this will boot the laptop without the graphics driver (VGA mode,all the icons will be large sized), so if the screen stays the same you know it's not the driver. If none of above fix the fault then the screen is faulty.
Apr 17, 2007 | Acer Aspire 3000 Notebook
LG 42LC2D 42 in. LCD HDTV Logo
1,001 people viewed this question
Ekse
RONALD CARTER JR
